Both are comparable lah, Beng. I have heard only one shortcoming on KW2 - cannot clear rims like ACS type 2/3 - but not many E92 owners would be using those rims. Besides wheel clearance, KW2 actually has more "thread-counts" - hence can drop more than PSS9. Also, PSS9 tends to have some minor creaks after a while - but hardly noticeable to some. So, both are pretty comparable.Ahbengdriver said:I was TOLD BY SOMEONE Bilstein is >> than KW ?
T6;230158 said:It is easier to make damping adjustments on a PSS9. It is such a pain in the ass to adjust rear damping for KWs. The rear shocks have to be taken out first.
I shd say KW 2 is below PSS9 in terms of adjustability. KW has a higher model called KW3. KW3 can adjust both bound and rebound. KW2 can only adjust either bound or rebound. Can't remember which is which.
Sting said:Actually for the E90, the rear adjustment is also rather difficult for the PSS9. You have to take out the lining of the boot to adjust since the adjustment is from the top. But you are right that you do not have to take the entire shocks out.
Correct, need not remove the shocks, but Clarence is correct that the lining has to be removed to adjust the settings......Azrielsc said:For the E92, I don't think that u have to take the shocks out right?? Hmm... let me ask Ah Wee!
Azrielsc;230476 said:Thinking of asking Ah Wee to cutout a piece on each side to access the shock, instead of removing the entire lining.
