centurion
This article is excellent reading for anybody considering BBKs. Now, some clarification needed. Discuss in terms of BMW cars if possible.
StopTech : Balanced Brake Upgrades
And if really so smart, why the need for the next paragraph `to tune the ABS/TCS/ESP' since brake balance is more than sufficiently handled by the intelligent brake proportioning valve?
And there is a local post here by the disreputable pointing to some resources which I can't find online and the guy can't find it too. Which I don't quite agree that he place so much faith in the EBD especially after Shaun already say not all EBD is alike, much less a Scion tC EBD, unless Denso > Bosch: Where can I change my rear brakedisc? - Carma Online Forums
More resources:
Extended stability control: suppliers are adding greater functionality to electronic stability control systems to improve safety and entice car buyers to check the ESC option box Automotive Design & Production - Find Articles
Wolfgang's ML Page: ABS to ESP
Charts for ABS pressure and braking force shows variability
Wow if all this is true then we can upgrade to BBKs with impunity and the bloody Stoptech article is FUD.
Shaun, come in please and comment.
The brake line pressure thing - serious??? Seems to be not compatible with their statement that it uses ABS hardware, coz I thought most ABS is just 1 or 0, brake or don't brake. The Bosch ABS controller really so smart???EBD
Electronic Brakeforce Distribution (also referred to as DRP, dynamic rear proportioning) - An electro-mechanical control system designed to monitor and influence rear wheel dynamics, and ultimately foundation brake (front-rear) balance. In so many words, the EBD utilizes the ABS hardware to function as an "intelligent brake proportioning valve." Unlike a traditional mechanical proportioning valve which is limited by design to one kneepoint and slope, the EBD algorithm relies on closed-loop feedback to continuously monitor rear wheel slip, adjusting brake line pressure to the rear wheels as appropriate.
Taking this into consideration, does not the introduction of a BBK in front, screw up the balance and destroy the tuning? If the tuning is destroyed, wouldn't the braking distance be screwed worse because of the inability of the rear tyres to be used to max traction?Technology Dependency - ABS/TCS/ESP
The calibration of modern ABS/TCS/ESP is a complex and time consuming processes entailing the setting, or "tuning," of literally thousands of algorithm variables. These variables define the base vehicle characteristics (braking system included), control limits, and expected vehicle reaction to control activity. For this reason, one control algorithm may be utilized on several applications, but each vehicle requires its own unique variable set, or table.
More resources:
