e46sg
I have just changed the washer pump located just beside the reservoir. Not too sure if that is what you call the sensor.
I found my leaking when i constantly had to top up, then i poped the bonnet and found traces of rust on near the reservoir. Guess if its the pump leaking then there will be rust, otherwise you should be able to spot leaks if its from the reservoir.
Anyway, its simple to replace the pump, i did mine at 40 dollars for parts and changed it myself. Note that there is a filter that you need to buy for about 3 dollars.
Hope this helps.
Hope this helps.
