LAN Setting: Privacy Control
MapleLeaf
Users Awaiting Email Confirmation
I am on Windows 7. Internet cable via company ethernet LAN.
What do I need to set to ensure that other staff cannot access my computer via the LAN?
Re: LAN Setting: Privacy Control
Thanks.
Where do I go (setting) to disable file sharing?
Password? As in Windows log in?
MapleLeaf;945558 said:
Thanks.
1. Something like network connections, then there's something like setting the connection as "public" , "home" , etc . And there's other file sharing settings in there somewhere (use the search bar at the top right in Windows)
2. Yep
Are you joined to your company's Domain? Domain / network administrator may have access anyway.
Precisely. I am using my personal notebook and I want to block my network administrator from accessing my data.
Red_Bean_Bun;945589 said:
Install a firewall software on the machine and ban everything ....
Can recommend an appropriate Firewall? Don't mind paying a proper one.
Why do you need to be on the domain? For file retrieval on their server? And to connect to internet via lan?
Else just make another account.
Firewall won't work, is for intrusion attacks or what not, your admin have rights to somewhat view unless like what I suggested earlier
Just use Windows firewall to block file sharing and printer sharing.
Or just don't use the LAN lah... ;P
well if you remain offline, it will work :p
If you control the FW.....just put the first rule deny all incoming (tcp udp icmp etc). Then ok already. network admin cannot do anything. even if the machine already joined the domain.
Kaspersky .... small footprint...non intrusive.....robust.
