carbonfac3d
Anyone tried it on older model Bmeers??
How does it function??
ryan;445935 said:It's a factory build. No one i know has done a keyless entry, unless im wrong..
carbonfac3d;446266 said:Haaa....TJY..correct ..i was more thinking on the programming of the frequency aspect. Anyway what alarm did you use for the keyless??
tom_ting;446735 said:BMW comfort access requires the driver to tap on the door handle with your thumb above the key hole. once inside, you can press the start button to start your ride w/o having to insert the key fob too...! simply awesome. i like it too, but my car dont have it. i want to retrofit too.
clar;446737 said:It's awesome if it works. I ordered comfort access with my car and the damn thing had problem since day 1. Sometimes it works, other times, it has a mind of its own. I usually look like an idiot dancing around molesting the door handle a few times before it yields. Sent it in and they found an antenna not working very well, but the replacement part is taking ages to order...
