Just change my rims from 17 to 19". Now at times I feel my tyre
Re: Just change my rims from 17 to 19". Now at times I feel my tyre
fantastic3;675406 said:
Stick to the recommended factory specs 245-35-19 front n 275-30-19 rear,
you shd be ok.
Yeah i m on this spec too. Yr tyre is of higher profile but also wider than recommended. Before you change to smaller tyre, make sure it fits your rim. For e60 it shld be 8.5 front n 9 rear.
hitmee;675364 said:
What do you mean?
I asking whether he bua tire when turning that time or when the road is bumpy then his tire keep buaing the inner fender.
If turning bua means Rims too wide, if rebound bua means tire too tall...
Thanks so much bros ESP to fantastic3. Changed my tyre to the factory spec contact extreme dw n wow it did the trick n the tyres is the best I have felt so far!!!!
can share what rims you gotten and from where thinking to upsize too
if u dun wanna change ur rims back to 17 then maybe u can change the car instead.
I changed to M5 19" from this forum bro
I am not sure bro but I think our bro fantastic 3 got mentioned earlier
Just go for fender rolling.
I had the same problem after switching to 19"s . Tyres will rub inner wall of fender on the highways going over humps (with passenger).
:chinese:
