In deep shit...what should I do?
Ahbengdriver
Legendary 10 Years
came back late from Jaybee last night. Topped up at Mobil before returning to SG as usual. As it was getting late, in my haste, I picked up the wrong fuel-gun and pumped some diesel into my car(should have taken the other one for Synergy-F1). Never did a more stupid thing in my life ever.
Luckily I was shouted at my the kiosk attendant there and I stopped immediately. Think I only pump like 1 litre of diesel.
The more important thing is what should I do now man?:angry: Go to BVO and get Ah Hwee to flush my fuel tank?
Re: In deep shit...what should I do?
i think diesel is more heavy than petrol, your engine is makan-ing diesel now ?
call BVO tml and check ? or call PML now ?
look ahbengdriver
If you make a similar mistake with a petrol car, by putting diesel into the tank, then you have a major problem on your hands. Having a little bit of diesel in your petrol makes the fuel burn easily with very little heat and this will make your engine detonate, knock and destroy itself in a relatively short time. So no matter what don't start your car, immediately call for assistance. But don't worry, the problem can be fixed and your car will run normally after being drained and cleaned properly.
Soruce from : Women24 - Your voice, every day
A google search came up with these:
What happens if you put diesel in your car instead of unleaded gasoline? Would it run at all?
"Diesel fuel put in a vehicle designed to run on gasoline will not damage the engine mechanical system, but will depending on the amount installed cause a problem from poor performance and excessive exhaust smoke to engine shut down. Diesel fuel fires by the heat of compression, not by a spark plug. The only solution is to drain the fuel system as much as possible: fuel tank, filter and if possible "blow out" the fuel lines. The reason for this is that even if the engine runs on the mix of diesel fuel and gasoline the catalytic converter will be severely overloaded by the unburned diesel fuel, and the engine management system will not be able to properly regulate the engine operation. You can count on "check engine" light codes for cylinder misfire and oxygen sensor problems. Removing as much diesel fuel as possible and running the vehicle on gasoline for a while should resolve these problems"
"I have personally seen an instance where diesel fuel was inadvertantly put into a gasoline powered welder (4 cyl. engine). It started to smoke profusely, then stalled. The diesel fuel was drained from the tank, gasoline put in, and after cranking engine for about 1 1/2 minutes, it started and ran fine. Diesel fuel will not ruin your engine. It will foul the plugs, and may cause trouble with modern fuel injection systems, requireing flushing, and purging of the system, but that's about it."
"It wouldn't run.
You would need to have the engine, fuel line and petrol tank completely cleaned out and any filters replaced."
"Diesel motors are quite different to petrol engines, as the diesel combusts in the motor spontaneously, rather than needing spark plugs to ignite it. "
but 1 litre of diesel to your tank of 60+ litres of petrol, should be no problem ba ?! dont quote me...
maybe your engine is like drinking kopi everyday but today just drink kopi po, mix abit of Milo powder.
We go hawker eat, we will sometimes eat Char Kuay Teow with some hair from the aunt, i guess it's okie. You won't be rushing to the A&E right ?
Assume you are posting at your comfort of your house computer, means you reach Singapore and drive home smoothy with diesel in your tank. Maybe your engine can accpet the "kopi po" ?
Damn... hope that nothing happens to your car!
hitmee;187531 said:
april's fool joke is it???
Yah. should be!!! If not, then Ah Beng is dam sotong!!
'The Great White'
Should be ok up to a certain small percentage..5-8%? The most your cat converter spoil only. See if any check light come on! if not, you may just get away with it.
Or, have Ah wee drain out all your fuel asap! and do a flush! But bring to him 3-4 litres of petrol for him to flush!
Ahbengdriver;187581 said:
Can diesel be diluted with more petrol?
all the while i tot the diesel pump-gun cannot go into a petrol car fuel tank opening???
but think 60 to 1 is safe.
Wah... you damn good man... lol... hahah!
just because you got triad backing don't think you won't get whacked for posting such things ok! some brothers even helped you do research...!!! hahaha...nnb
holy shit!! Suck our your tank NOWWWWWWWWWWWWWWWWWWWWWW. Cannot have that in there, OMG. I had a mate who did that once in his brand new, 1 day old ducati 996, guess what happen? KABOOM!!!!!!!!!!!!! Ducati die
I pray that the attendant wass dam cute, that why you blur and pump diesel!!
Ah Beng Driver becomes Aprilfool Bluffing about Diesel.. kekekekek.. Chow Ah Beng.. Hi Five !!!
