Hi there, I have recently acquired a set of Hsport sway bar for e46m3 but have decided to put them in the market. Pm or sms 90056444 if you are interested. Here are some details of the sway bars.
Sport Sway Bar Set
Item#: 22826
2001-2005 BMW E46 M3
Enhance the cornering performance of your M3 with a set of H-Sport sport sway bars. Our M3 sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the M3 handling characteristics are excessive understeer and limited roll control. Our H-Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded understeer is eliminated and the handling becomes comfortably neutral. H-Sport sway bars feature a durable powder coat finish, greaseable bushings, performance rear end links, and 6 different tuning rates via multiple end link positioning.
Specifications
1 3/16” (30mm) Tubular Front Bar 3 Way Adjustable. Rate Increase vs Stock +11%,+28%, +49%.
1” (25mm) Tubular Rear Bar 2 Way Adjustable. Rate Increase vs Stock +79%,+105%.
Sport Sway Bar Set
Item#: 22826
Specifications
