How to use the Michelin Tyre Selector to find the recommended tyre pressure for your BMW
hamza151
Michelin Tyre selector highly recommend you to find the tyre pressure of BMW. It also gives you the recommended tyre pressure of your BMW. The most accurate way to measure the car tyre pressure is to on the indicator of your car. These are related to tyre pressure recommended by car manufacture company.
First, select the recommendation of your BMW tyre selector fillers.
Once the setup is completed you will scroll down to find the exact pressure of the tyre.
most car maker provide information about your vehicle tire pressure (even the recommended tire size) in Owners Manual or A sticker pasted on driver Door Pillar or Fuel cap cover.
it recommends you all pressures for diff application like normal load / heavy load / M+S (mud + Snow for winter use) for diff tire size diff pressure for certain vehicle.
my personal POV you can adjust to your own preference but it has to be within the recommended range and not exceeding MAX working pressure of the tire (usually max 3.5 bar)
Generally LOwer pressure for COmfort
higher pressure for Fuel economy and heavier load and high speed driving
JUst MHO
last but not least
Tire pressure is a very important part of tire maintenance it affect your tire life span / fuel consumption / most importantly the Handling of the Vehicle etc
