smokeyrobinson
Can find it anywhere in the iDrive.
For E60 and E65, thanks!
Rkeeper;685826 said:For the E60, try pushing the button which adjusts the side mirror to the right, if you want it to tilt while reversing, and to the left if you want it to not tilt while reversing.
Left = Lock the tilt
Thats how I remember it.
mohankls;922738 said:Hi guys,
suddenly, this morning my left mirror didnt tilt when i engaged reverse gear...
It has been working perfectly since Day 1.
Has anyone encountered this before?
Any advice?
Thanks
lim_ck;922745 said:check if the switch is pushed to the correct side. just push to both sides and try engage reverse gear and see if it works.
also check if your windows can wind down and up. test this after parking the car for a few hours. if you have folding mirrors, also try to see can fold/unfold or not. if windows up/down fail and folding also fail most probably your driver side switch pack has failed.
mohankls;922755 said:Thanks bro..
When i parked earlier, the folding mirrors worked, ie: it folded when doors were locked..will chekc for windows later.
Hope the tilting works when i see her after work..fingers crossed..!!!
yegh55;955714 said:Hi All,
Just collected my Sept 09 E60 525. Need some help advise here:
> My side mirrors cannot be closed using remote control. Only can do so using panel option inside the car. Is this normal? I read somewhere seems to be an option when pressing the 'BMW' button for 3 seconds.
Thanks to All!
Thanks to All!
