marklee said:yeah i met wayansurfer, turbular and gwumpus before. anyway wana ask ya whether u have any electrical probs...my lights keep getting blown. changed my headlights only 3 mths ago and one of them is blown again...one of my rear lights also gone...you know wats the prob??
yeah ive installed the steering already..simple job. hmmmm actually i dunno which steering wheel it is..its not the mtechnic 2 one..gwumpkus said:is something shorted?......
managed to change your steering yet dude?.... i reserve an electical test pen for that kinda work...small flat blade to pry the logo emblem out, without potentially damaging the leather....hehh.. the the socket to undo the nut, unplug the wire...swap it..u're done..
hehhe..
jawzsg said:Don't seemed to have encountered much electrical problem, more of poor connection due to wear and tear at the lights sockets. I have most of my fuses changed when I took over the car and I can tell you that they are often culprits to electrical problems. As they are small and cheap, many people tends to forget about them, however, like any other components, they do wear down with time.
Another problem is that your bulb power demand may not match your output. Hence either you buy bulbs that are rated 55W and no more or upgrade your fuse if you put in higher wattage bulbs. Some believe a voltage stabilizer and grounding helps. I have not done either of both but I intend to DIY the grounding when I have time to explore my chasis.
