Housing Loan query
C3P0
Fellow forummers,
If I am buying a property, and the housing loan requires me to pay $5000 monthly installment (assumption).
How will the bank determine if my monthly income is sufficient to take up the loan? Is there a formula that banks use?
(I assume they will also take into account my other existing housing or car loans.)
Thanks in advance for advice.
Re: Housing Loan query
Bro normally the bank use the gauge of 35% of yr salary (declared).
Yes they take yr car loan and other loan into consideration. And also yr payment on yr CC.
If u have certain amount of funds in yr bank, loan should not be a problem. (If yr salary does not qualify for the monthly payment.)
It all depends on yr relationship with the bank that u will be borrowing.
Thanks bro for the input. That means, monthly salary must have $15k in order for bank to approve a loan with $5k monthly instalment...
Btw, what is CC?
C3P0;445115 said:
Thanks bro for the input. That means, monthly salary must have $15k in order for bank to approve a loan $5k monthly instalment...
Btw, what is CC?
CC - Credit Card.
It can also be a combine salary between u and wife.
Again it depends on yr downpayment.
FYI now the banks will first look at Credit rating.(They will check with the credit bureau first) If it passes that the rest is just formality and yr relationship with the bank that u will be using.
Hope info is helpful for u.
Cheers.
WHITENIGHT;445120 said:
CC - Credit Card.
Cheers.
Heng, bo CC debt, ha ha.
The combine salary part I know, because my current property I use my own payslip not enough, bank ask me to add in my wife's pay. very malu :chinese:
Ok, i later pay $5 to see my credit rating. Should be ok :D
Thanks so much for the input!
Based on MoneySense, total long term commitment should not exceed 35% but I think banks use 40%.
Not many pple will advise this but I recommend opting for maximum payment and shortest possible loan repayment period to reduce the cost of borrowing. Next, make lump sum payments periodically without reamortisation to further shorten the loan period. If you choose this strategy, make sure the agreement does not have penalties for early repayment. If yes, ask for the clause to be cancelled out.
A good banker should be able to give you the right advice.
Thanks bro!
just to let you know, the credit bureau does not provide you the same report as the bank's...
your $5 report is a very simplified version of what the banks will obtain from the bureau. the banks report are very much more comprehensive
Yup, was thinking of that when taking a puff, kind of figure it out that my report must be machiam simple one.
Btw, thought of extending my HDB loan tenor so that I can reduce the monthly instalment paid.
Then stick to my E46 instead of buying new car - so that monthly car instalment won't increase.
Then use my little remaining CPF to repay a bit of pte housing loan. Bingo, another reduction in monthly instalment amount.
And if economy good, must change job also, so that monthly salary increase.
If all done properly, should be able to get the new housing loan I wanted. :p :thumbsup:
C3P0;445201 said:
i found this, quite useful:
Home Loan Calculators
No change in their policy... still based on 40% of gross income.
UOB is a good choice. StandChart offered the lowest rates on paper at that time but I decided to take my loan from UOB and it turned out to be the best deal over the life cycle of the loan :D
Cool. I also compare here compare there, like buy vegetable like that, and end up with UOB.
But being banks, they all suck blood. The so called floating rate loan is a joke. But that's another topic. Next time then share my experience.
SLK69;445229 said:
Nobody loan you, call me. - iScoupe say one
Gam dong....!! touched....
iscoupe will be guarantor. If i run away, you can chop his hands and kkj. guni say one.
I know. All our banks are like.
I did a Houdini muahaha :lol:
mine still safer Maybank fixed 3 years 1.6% , 2.2% & 2.9% 4th see how kekekeke....
i think board rate or watever floating rotor rate they call will soon go up - i think only
Today UOB got fixed 2yr at 2.28% & 3rd year brembo floating rotor rate 3.75%
Robot, you want a 5k per month repayments loan for a house? You buying 10 million dollar house issit?
he buying 10million sperm from me but took a loan from Bobby. Robot will repay his 5000 sperms a mth to bobby, tat wat robot can produce due to the older version robot software version 0.1.0 :lol2:
Sounds reasonable....
yup yup, if the good sentiment continues, i/r is on the way up up up.
Today UOB got fixed 2yr at 2.28% & 3rd year brembo floating rotor rate 3.75% This is attractive if after 2 years it allows us to switch.
I used $5k as example only la. I am actually looking at $6k :nehnehhh:
Ok serious. Even if $5k per month instalment, for a 25 years loan, the loan amount will probably be around $1m only. How to get $10m house....not possible lah....
