Honk and Vibration
swt
hi all!
lately my honk has been going off on its own...damn embarassing...happens often especially when i am turning...the honking stops when i tab the honk gently a few times...
i suspect it's the wiring problem...or should i just change the steering wheel.
also while car is idling there seems to be some vibration going on....is it the engine mount having problem?
swt
Re: Honk and Vibration
SWT - if yours does not have airbag, yank out the horn cover that's on the steering and check if the wire is frayed or loosed. Sometime a foriegn object may have cause the "short" while you are rotating the wheel.
Engine vibration can be caused by several factor. However if you do not experience erratic idling, it's often due to the engine mount. If you also experience slight knocking when up or down shifting, pretty confirmed that mounting is worn.
thanks joe! so afraid to yank it out but i will try...
as for the vibration it's quite subtle...feels like sailing on a boat with very gentle waves...hahah
gonna head dwn m n q soon...
steering honking prob is definitely wiring got prob, most likely a short circuit or something.....easy job, just get the workshop to open the steering middle piece and test the wiring
thanks guys! yah i followed jawz's advice, yanked out the cover, ripped off the contact point whic was broken anway...now the right hand side honk is deactivated...left still going strong!
So next time when you press the right side remember to shout hor.. else can hear.. kekkekeke... come for next meetup and see if can DIY for you..
i alway think the most effective alert comes in a form of a Flash like those found in cameras but much brighter...will cause accident lah but will give the next guy the best alert of his life....hahahah
i am used to having just one side honk...no worries bro!!
