Hifi system Alpine retrofit for F30
sonnguyen
The original speaker of F30 base line is so bad. So I ordered a kit of Hifi system Alpine:
BMW Hifi system Alpine
List of speaker and cable
Midrange speaker
Treble
How to replace speaker on Youtube
[tube]http://youtu.be/TBR33bQdMBg[/tube]
To be continue...
Re: Hifi system Alpine retrofit for F30
Looks good. You're right about original base BMW sux big time.
Awesome DIY work you got going there sonnguyen !
that's why bmw got alpine, harman and B&O to chop robert ... hehe
Sonnguyen, Is coding required or is this a direct replacement?
Looks great.
Where is the sub-woofer?
This setup only change the pair on front door panel.
Yes, cause it is OEM set so can coding to adjust equalizer.
davidtch;1040227 said:
Looks great.
This set reuse 2 subwoofer and 2 rear speaker. It has separate channel for each speaker.
Please help
I have A5, A6 jacks and dont know where to plug in.
Where is X5*1B and X28*1B
I bought this upgrade, but not received yet. How do you code it? What I need to code? I would like to install myself.
Best regards
Best regards
After upgraded, the sound feel better, no need coding. Coding just for equaliser control.
Thank you. Do you coded? If not coding I can adjust bass, treble as the original sound?
Umm, didn't know that only 335 come fitted with Harman Kardon set!
Is the 2sec delay issues between rear and front speakers still there on F30 Alpine system?
i had it installed and there's no 2sec delay that i noticed.
Btw anyone did the coding? Sounds great but i do feel the treble can be a bit overpowering, Ive read that coding from Stereo to Hifi will make it even better.
Just had this done with elebest. Definitely need to recode - the sound is very natural after recoding- otherwise it is too harsh as the original setting was for the stock system without tweeters. Max at elebest is very helpful. Love the upgrade - definitely good value !
