HID question
jawzsg
Legendary 10 Years
I think HID 7 defines the design of your bulb holder in your head lamp, hence it should be universal. Anyway for info, LTA forbid HID installation if your model does not originally comes with this option. To power the HID lamp, you will need a couple of balast (usually comes with the kit), hence, got extra 2 ding-dong to hang around your engine compartment.
That's what I know, hope it helps.
H7 is a model number, no doubt I think any other makes with H7 HIDs will fit in your car, however be warned that you will experience the headlight faulty indicator permanently flashing on your speedo cluster...
Unless, like AzrielSC mentioned before, either you remove the fuse for the warning indicator OR purchase a set of aftermarket HIDs that has the bypass adapter...
Alright!! all bros!! that's good 1 ask all question solve... 2 thumbs up!!!1 :laughlik:
As long as the HID is H7, confirm will fit your car. The brands that I have seen which do not produce error codes are Xelux and BrightStar
Regards,
Shedden
Oh ya.. that Xelux also comes in a fully submissible model, so you can use it under-water .. kekekekkkee.
The error code will not do anything else right???
You might like to refer to the link below before modification seeing how LTA is issuing summons freely..
Quote ST 20th Nov 2004:
" The most frequently issued summons was for lighting offences, including cracked or misaligned headlights, and illegally modified lamps, like those fitted with powerful xenon bulbs inside inappropriate casing."
" Anyone who fails to do so can be fined up to $1,000 or jailed for up to three months for the first offence."
http://www.onemotoring.com.sg/publish/onemotoring/en/topwebwide/faqs/vehicle_modification.html
Bro junior... thank u for ur advise... but bo pian lah back to 1 old saying if u want to mod dun scare, if scare dun mod lor.... :thumbsup:
cyberfreaker
