hid kit
Status
Not open for further replies.
curly
h7 and h4 hid kits for sale. 6000k brand new.
Bought for friend but friend don't want.
Selling at best price $150.
Re: hid kit
curly;336787 said:
any one?
i can get it swapped for any other bulb size also.
brand new!!
=D
Can fit for E-36 fog lights or high beam? What about installation? i already have hid's for my main lights.....any more space to fit?
Re: hid kit
for e36 fog lights i think it is almost the same as your nomal beam....same installation concept. there are people doing it already... what bulb type it is using i'm not too sure? must take a look. High beam should be no problem like the fog lights but then probably will have to find space to mount another 2 more ballast or more... i'm not sure if we can tap all 6 into 2 ballast.... nv try b4...
installation i could probably do for you for a small price or you can get a workshop or even diy yourself... quite straight forward i guess...
i can get slim ballast type for you if you really scared not enough space but will cost more. but i think space can find one...
Re: hid kit
hi,
i don't think that should be a problem on the burning issue. quite alot of cars on the roads have hid already. i have them installed on my car also. however, you may need to get a little device that will tell your obc that your bulb isnt blown. because xenon bulbs have no filament... i'll check that out for you if u're interested. i believe bvo should be able to install the kits for you properly.
Re: hid kit
hey darky,
i've checked with my distributor. i can get you the obc warning canceller if you want to use it with the 35w kit. or if you want a 55w kit there is one with the obc cancller already built in. so installing in you e46 shouldnt be a problem.
if you want we can plug in the kit and try it out first. if it works then we can install it. if not then its ok... pm me when you wanna try if you want =)
Re: hid kit
Curly, Im confused. At first you say you got it for a friend but yyor friend doesnt want it. The you said you can swap with other bulb size, now you are saying, you can get the 35w and 55w from your distributor.
Whats the deal? Sounds like you have several sets for sale. Are you a reseller?
Re: hid kit
Thanks all for the headsup.
Thread closed for investigation.
Status
