waynechai;495605 said:How is the Helix brand for hi-lo?
Compared to Audio Control?
Anybody has the experience?
waynechai;495797 said:Err..Richlee7, you got me confused.
"not the best hi-lo works with all signal processors, esp those that have been designed for OEM level (noisy) input, so be careful when u match hi-lo convertors."
Does this apply for AC LC6?
LC6 at USD139, and including shipment should reach Singapore at no more than SGD250 seems a steal...
i assume its oem hu to normal (without built-in dsp) amp, so SHOULD be ok ... LC6 fm audiocontrol... of cos good! not looking at the LC6i? :thinking: ... all the best anyway!waynechai;495836 said:The hi-lo will most probably go between the head set and the amplifier...no dsp for now...
LC6 good enough?
richlee7;495886 said:i assume its oem hu to normal (without built-in dsp) amp, so SHOULD be ok ... LC6 fm audiocontrol... of cos good! not looking at the LC6i? :thinking: ... all the best anyway!![]()
david navone!!! hahahaha ... reali long time haven't met people using DNs liao, but they're really good, imho. also veri good value for money ... btw, it was my DNs that had problem with the 701...waynechai;495889 said:6i of course....
I think I will go for whichever is cheaper..ie 6i and Helix...I used to be using David Navone..and seems okay too.
fuzzy;496178 said:Been using my Helix Hi-Lo for almost 2 yrs now. So far so good. No problems.
waynechai;496235 said:Have you ever use LC6?
Any difference?
How much you pay for it by the way?
Any difference?
