help required. noob here.. 335 need overhaul...
lastcabin
Overhaul auto gear box,
Replace valve body.
Servicing.
Wiper water spray motor
Glove compartment lock
Front suspension arm,
Coolant hoses,
Computer wheel alignment,all repair cost is about $10K.I fix for
You,Thank.
Is the price reasonable...?!?!
Re: help required. noob here.. 335 need overhaul...
Definitely a Hara-Kiri of an MP. Opps I mean of a 335.
How can be it 10k.....I suspect it can be done in under 5k.
Assuming you source the parts yourself.
Overhaul auto gear box, [what type of overhaul? Ok lets say change those so called clutch plates, solenoids, reprogramming, etc...maybe $2k max?]
Replace valve body.[Heard from bro a valvebody for a 320i is only around $1.9k. Not sure for 335]
Servicing. [what servicing? Engine Oil? $250. if DIY, maybe $125(half) ]
Wiper water spray motor [should be $200 max?]
Glove compartment lock [dunno. Maybe $50 for labour?]
Front suspension arm, [both left and right? Maybe $300 parts]
Coolant hoses, [should be around $200 for the 3 key hoses linked to coolant reservoirs]
Computer wheel alignment [$50 -60]
So add in the appropriate labour. $5k definitely doable if you procure the parts yourself andf be a bit more adventurous.
Gearbox max $3k
The rest small issue. Go to eng soon get parts less than $1.5k with labour.
10k you can do engine overhaul too i feel
Oh dear.. What a noob.. Went to them due to some jerking issues, gear jammed at second or forth most of the time and need to restart for it to function normally.. Was told to do a overhaul but due to time constraints was recommended to do megatronics. However now they actually had time to do gear box overhaul. Not sure what it means and what it includes though. Reputable workshop within this forum. Hmmm.. Asking for 6 months warranty.. Cannot do anything else since I udnerstand that work had been underway..
What else should I ask the mechanic or what else should I know other than knowing it's overpriced repairs..
damage done or still planning?
else go to another workshop to compare price first...
lastcabin;1112663 said:
Damage done.. Trying to ask for discount now..
looks like abit too late? hope you got the discount ..
Which workshop is that?
Servicing$318.86.
$107.
And wheel alignment
$674.1.
Coolant hose.&171.2.
$267.5.
$7950.1.
This is the price list.. sigh
lastcabin;1112712 said:
Servicing$318.86.
$107.
And wheel alignment
$674.1.
$267.5.
$7950.1.
Your price list sounds very much like you went to PML.
Most of the prices quoted above can be achieved at half the quoted price...
Try to bargain a bit more bro. Good luck!
Servicing$318.86.
$107.
And wheel alignment
$674.1.
$267.5.
$7950.1.
overhaul gearbox ....almost $8k?:wtf:. That's almost like a new gearbox's price right?
What is overhauled?
Thanks for sharing bro.
335 N54/55 engine using Engine Oil 5W-50?
Anyway that's why I have also learnt that EO needs to be changed regularly, and not follow the stupid OBC or stick to some 10k km intervals.
Seems that item 10 is a bit higher than normal. A full gearbox rebuild with original BMW rebuild kit should be around +/- $5k all in if done in Sg and anything from 2-4 days.
I had the same issue on my 335 gearbox last week. Kept hanging at gear 3-4 and couldn't change gear till I restart my car.
the yellow sprocket transmission fault light came on. My guess is it is a fail/safe limp mode to prevent further damage as I'm still able to drive lightly around and run my errants until I had it checked out thoroughly.
I decided to rebuild it as I still have over 4 yrs to go on my ride. Better do it now than later to get more 'mileage' out of the rebuilt gearbox.
6 mths warranty of the gearbox is quite standard when you do a rebuild.
fabetvnfun
