fooman700;166050 said:anyone knows if it is possible to fix a twin exhaust tip to our e90 320 ala those on the 323? TIA
ACSCAB2;166090 said:Hi Fooman,
I tink wat u meant is to fix a tip, n not the catback exhaust? tis is also possible. all u need to do is to cut the current exhaust end, then fix a Y-joint n weld the twin tip. No downside here in terms of power n u wil not lose low-end torque like some of the aftermkt exhaust n it shld b the cheapest option amongst all.
However, do note dat if yr ride has no bodykit, then it may look weird bcos the y-joint can be seen fm the side....
hope tis helps.
Scuderia;166096 said:Understand that Y joint at exhaust end is not a good idea as the other side will be sucking air instead of exhausting air.
ACSCAB2, what is your next ride? Any updates?
ACSCAB2;166135 said:Bro Phil,
No luck for me sir so far in gettin my dream car; saw a couple of 911s n a maser spyder but deal did not go thru. More keen on a maser spyder though. prob is not many in the resale mkt....any lobang?
hope tis helps.
fooman700;166193 said:bro ACSCAB2,
yes that's what I meant, tks for the tip (pun intended), actually I have fixed the Mtech rear bumper and now the single tip looks funny. but noticed bro scuderia mentioned that the y-joint is not a good idea?
cheers,
Scuderia;166170 said:Sorry OT.
Bro Ivan, I know an angmo guy who has a red Maser Spyder, have you seen that car?
ACSCAB2;166256 said:Hi bro, agree wif Phil on his comments but i tink if welded properly, shld not b a prob. I did tis for my former E46ers 318s n also for my current E90 320 as well. No issues n dont feel any loss in low end. I did it at Jeep Chee. Look for Eric. He shld hav wat u want....n agree, pls do something to yr exhaust...looks weird when u hav a kit wif a tiny single exhaust tip....
