Help needed for f30 passenger lock issue.
Valente
Hi bros. My passenger side lock problem came. Out of nowhere. Can't open from outside now using keyless entry. When I'm in the car. I only can open the passenger door manually from the hinge inside from the car. When the car moves. All the locks will auto lock but not the passenger side anymore. I google and may I confirm it's the lock actuator problem?
Bro, where is the workshop to get this done and what is the damage incurred? Just got a 316i didn't expect all these to come so fast. Hehe. Kindly advise. ^^
Try look for Bavworks to get it solve. Contact William at 81833083
Had this issue before, did a scan found a bunch of error codes. No issues so far after clearing the codes! Been about 3-4 months since.
Mine was driver side passenger door remained locked after unlock car, can’t open from the inside, or sometimes lock from outside that door never lock. Trying to open from the inside the door lock thing goes up and down but doesn’t open.
But if your door doesn’t lock at all then I believe it’s the actuator problem then in that case it’d be completely dead no response
Your lock issue gone after clearing the error codes ?
Mine is everything has to be done within the car. Manually lo bro. So lock actuator died.
