Help:dtc module and abs error code after installing coilover
Re: Help:dtc module and abs error code after installing coilover
Mine was the reverse. I got the DTC warnings quite frequently when my stock shocks are going. Improved once the shocks were changed.
How do you reset it bro?
I didn't. The DTC warnings flashed because the shocks were gone and I was not getting traction when needed. Changed shocks, better road holding, no more warnings.
Your case seems odd. It's the reverse. Best to go back to the workshop and get it checked out.
DTC module is quite finicky - many tentacles to other ECUs and sensors.
Get the fault code via a scan then we'll have a better idea ......
Sometimes a battery crapping out would have these faults as well.
quatdieuhoadmgdsg
