Red_Bean_Bun
And so I decided to look into this and I have decided to code the ride to disable the NIC as well as the soft stop.
What happened is that when the car starts braking to a stop at a traffic light - the soft stop feature kicks in and
tries to reduce the brake pressure to get this smooth stop automatically. But all it did for me was to cause jerking as I modulate the braking. Yup - me and the ride seconding guessing each other. On top of that, being that it decides for me when it releases brake pressure - I think there is a risk there. So I turned it off.
That is not all - when it finally comes to a stop, the torque converter disconnects from the drive train so that while idling in D - it saves you petrol by reducing the load on the engine. When its time to move off - the torque converter connect back and causes a bunch of jerking. Seriously - how much fuel saving can you get from this ...... This is especially painful during parallel parking (TC connect / disconnect incessantly) and it caused me to crashed my front bumper into a concrete block when it decided to lunge forward while I was trying to inch forward. So I turned off that damned feature as well.
One more thing - Initially, I had my hopes up with the new version of transmission software released and flashed this into my transmission hoping that it would help. That helped in other areas but still jerked in those situations. And according to the SIBs, it is suppose to turn off SS & NIC by default. But when I checked after flashing - it did not. So you would need a combination of flashing and coding to ensure that it gets done right ........
Now, its a lot smoother ..........
