wt_know
Re: Had engine tuned and "jerk before stop" is gone
see above reply .... the gearbox is replaced by pml under warranty.
AFAIK, flush ATF + replace oil pan + reprogramming will minimize the issue to minimum.
if want 100% resolved the only method is to replace the gearbox (new or recon)
Pendulum;594209 said:Have they managed to fix the jerk-stop?? Have the same problem on my E60. Looking for a solution other than a replacement.
Pendulum;594210 said:Did you ever fix it? What did it cost? Did you replace or otherwise?? I have the same problems too, though have not yet run the thing into the ground yet. Cheeky PML identified the problem while under warranty, did a quick fix by re-programming it and now that it returns - now out of warranty - they say I have no choice but to replace the whole box at 8K!!!*&^%$^%
