yendor
Guys, Before i actually start this thingy, I would like to gauge the response of grounding. I basically DIY grounding sets in my free time and have done so for my car.
I use 4GA size cables for grounding and install them in the engine bay as well as at the battery end in the boot.
Just to add a little, grounding enables the car's electrical system to recieve the maximum voltage to work it's best. Electrically speaking, the resistance of any piece of wire increases with length and decreases with cross sectional area. As the BMs use a battery at the back of the boot, there is a single strap across the negative terminal of the battery to the chassis and another from the chassis to the engine. All current drawn from the battery must come out of the postitve terminal through your fuses and such and return via the single negative strap. As that strap has some sort of resistance, all currents flowing through that wire creates a voltage drop and decreases the available voltage usable at the device.
If i do the straps, it should cost about $100 inclusive of installation. Any one keen?
Rodney
Rodney
