Leean said:Hi Bros, anyone here can advise why when you change to coilovers, u always set the gap between the tire and the fender smaller at the rear than at the front? Or is there something wrong with my setup.....thanks for ur advise...
Wayansurfer said:Mine would be 1/2 finger front and 1 finger rear. This would give it a menacing stance.
But end of the day it boils down to owner's preference
wilman2772 said:U walk back 3 meters, look at the side of your car! Tell me which fender is higher.....
U can look at mine if you dun have time....kekekeke
Why I want to have 1 finger gap in the front & -1 finger gap in the rear is bcos I want the car to be horizontally flat...
If you have the same finger gapping.....U'll find that your car's arse will be higher.....
Got it??
'The Great White'
Leean said:I thought there is suppose to be some ground rules to follow....I really dun know....if the leveling not right, it would affect the handling of the car...cannot just suka suka, rt?
kenntona said:Leean, you have to take your sideskirts and the clearance height into account. The normal height for most sedans is 2 fingers front 1 finger rear. My previous sedan was running on Hamann kit, and with that configuration could not clear many humps. My current ride is running on 0.5 finger front, 0 finger rear. Same problem with clearing many humps.
Chio, but your sank each and every time you hear the scrubbing against the humps......Azrielsc said:But damn CHIO!
