hi, like to check if any e90 owner here had experience fuel injection pump faulty before. This is the thrid time that it strike me again !@#$%^&&^ ... and the warrenty over !!!! Any lobang out here ???
This issue has been discussed many time. Search through the threads. Never drive the car when the fuel is below 1/4 mark. Always pump when is near 1/4 mark. The fuel is use to lubricate the pump too. Did you replace the petrol filter during the last pump replacement? A choke petrol filter will cause the pump to work harder and eventually breakdown.
