Fuel and engine treatment
sivaraj
Have anyone of you tried the Fuel and engine treatment. Planning to try it as my fc for my E90 is pretty bad.
Any feedback and recommendations welcome. Thanks.
Re: Fuel and engine treatment
Dont waste $ on those.
Have better control of your right foot and your FC will increase.
I support both his statement
If buy BMW & still care about FC, U might as well buy Vios.
Actually I own vios before. The fc is around 10, which is same as my current bm.
BMW engines are well made with no cylinder sleeves, the cylinder walls are all machined out of the engine block. Best not to use engine additives.
Then saf why dun use such to clean weapons but make us strip to clean ? Maybe your special cleanning can be recommended to saf
Then why u never ask saf?
I never ask saf is because i do not use such to clean the engine while freuquent oil change is good enough ...
If Ah boyz to men dun use then we dun use ...
wahahaha ...
wahahaha ...
Then good choice
playstation76;1113041 said:
Then good choice
SAF dun use mean cannot use ... wahahaha
good88compink
