galant1688
Upgrade Front BBK, therefore needed 12mm spacer to clear rims,.
Question:
What is the effect if we add spacer at the front only? Know about the inside tyre + bearing wear and tear.... but otherwise, any bro can share the effect of only spacer added to the front?
2) Do I also need to add a 12mm spacer to the rear to balance the equilibrium? Most of the time I know spacers are added to rear rather than front. Ride looks a bit weird with the front (spacer added) protruding outward more than the rear.
Is it recommended to add a 12mm spacer to the rear?
Question:
