Fault read out from OBD reader
Cochran
Hi ppl
Today first time using the OBD reader to see if any fault with my car.
Now is there three............ using the android program "Torque"
Fault log report generated by Torque for Android
Vehicle VIN:
Vehicle Manufacturer:
Vehicle Calibration ID:
Current Fault Log
P2184: Engine Coolant Temperature Sensor2 Circuit Low
P0420: Catalyst System Efficiency Below Threshold (Bank 1)
Pending Fault Log
P0430: Catalyst System Efficiency Below Threshold (Bank 2)
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Saw its link to catalyst system and engine coolant temperature.
R they serious stuff to be worried?
Thank you.
Re: Fault read out from OBD reader
The coolant fault is minor - P2184.
The P0420/0430 faults are indicating failing cats ..... clear it and see if it comes back.
Hi RBB
Thank for the reply.
The coolant fault if u remember. Is it the coolant temperature themostat sensor? I remember last time u read my car code and found this issue and i had asked the workshop to change for me. Dun tell me they didnt change it? Or cos they install 3rd party one then will have this fault? Mmm... Or they changed and didnt clear the fault?
As for the failing cats...... serious and expensive?
The coolant one maybe never clear code .......
The cat faults ..... Clear first see how.
Cochran;1080215 said:
Hi RBB
Ok. today i cleared the fault.
The coolant one still appear. Checked my receipt of last service which as them to change it. It stated as " to supply & replace radiator temperature sensor (after radiator outlet)". Different items or same as what the fault code stated?
The cats gone now...
From the description - P2184 - I think there are 2 temperature sensors ........
so meaning i should change the other sensor at my next servicing?
Ask them to check .....
