F30 Tunning Box
Status
Not open for further replies.
Re: F30 Tunning Box
Swiss chiptech is now 2 sensors also? The one I saw only had 1.
Actually, do you guys remove the tuning box before sending for servicing like oil change or fixing rattles?
Re: F30 Tunning Box
opps...sorry..!
you are correct, 1 sensor only, the other connector is bypass for the ECU.
Re: F30 Tunning Box
3005;975556 said:
Mine installed with JB, tried with high speed several times in NS highways; no problem. My advise is since you want to trick the sensors, get one with 4 sensors "tricked"!
So get 4 tuning box?
Re: F30 Tunning Box
No, there are some brands come with 4 sensors trick with only 1 box controller.
Re: F30 Tunning Box
paulho77;975624 said:
any tested and proven tuning kit for 328i ?? thks
Been running JB since day 2.... Using it for almost 8 months so far... Going fine... Easy to remove also, and leaves 0 trace... No codes...
Well, it does give u a drivetrain malfunction which goes away by itself after like 2 power on / off cycles... This is because the car is probably detecting some loss in torque or something.... But so far been into PML for repairs on other stuff and not detectable
Re: F30 Tunning Box
Hi Seraphblade, Did you meant by after removing the JB before serving, the drivetrain malfunctioning happened? Thanks
Re: F30 Tunning Box
yup, mine only happened once, the error go off after restart. :) Using JB for almost 2 months already.
Re: F30 Tunning Box
On TMC tuning. Not very good at low speed. Need go above 2k rpm to feel the magic. Amazing if right foot is heavy.
I take out and install back, both bo ta ji.
Status
