F30 new owner - Need Ext Batt for iRoad V9?
grainpixel
New Member
Happy New Year everyone!
My virgin post in this forum and new owner of a second hand F30 316i.
I have a set of iRoad in-car cam -V9 which I will like to install on the 316.
I will want it to have parking monitoring too.
Is it an absolute must to install/connect to an external battery batt?
I was quoted $380 (not even iRoad brand) for the extra batt, which I think its quite ridiculous.
So seeking advice from the bros here.
Thanks!
if you do not want an extra batt, u can try either not to run it in 24 hrs mode or if want, in power control mode settings, select power cutoff at 12.3v. There is a risk of car battery going flat though. Best if u have a voltage display like those u plug into cig jack can see voltage at times.
Thanks!
I have install a batt. $360 . Same ride with u .
Run it with external battery.
Otherwise, you will run here to ask question on error code.
Found the official manual....
Hope this may help...
... Refer to similar wiring guide on BMW Advance Car Eye Retrofit instruction, pg 10/11 shown the CAS / FEM module connections, cross reference to page 7 for the connector's detail.
  • BMW EBA 2288640 External Eye Kit Retrofit Instructions.pdf
