F30 Lights
Hello Seniors, I just gotten a 320i ED recently. Noticed the inner lights are not in use? High beam and low beam are all using the outer lights only. Can anyone tell me the uses of the inner lights ?
Re: F30 Lights
You have to have optioned Adaptive Headlights (bi xenon or LED) for that to happen...
Re: F30 Lights
Flyfisherman;1124720 said:
Tried but no corner light leh.....
You have to see Tony to code the corner lights.
The spotlight acts as the cornering light and needs to be coded.
You can also go to ELEBEST and see Max if you want to retrofit the original spotlight to whiter and brighter LED type that have the cornering light function when you steer the car or signal.
Re: F30 Lights
Inner lights in the main light cluster have only DRL function. If you google, there are people in USA who have successfully modded it to add xenon function but kind of blinding. Pretty major work though.
