F30 front fender leaks while refilling wiper washer fluid !
Hi Mates,
I noticed the leak when I was refilling my wiper washer fluid one months ago. The more I refilled, the flow of the leak at the front fender increased! Basically it seem to be bottomless! After I went to PML to get it fixed as my car still under warranty ,the service advisor told me that it's normal to leak as there is a excessive fluid pipe to drain out the excess fluid but another service advisor said it's not normal to leak. After I reached home and test it out, it doesn't seem bottomless anymore and I could finally see the water reach the brink but i could still see a Slight leak at the front fender. Is it normal to have a slight leak? Is it true there is an excessive fluid pipe in the wiper washer tank to drain out the excess water or fluid? Anyone had the same problem as mine? Need advices!
