F30 abnomal nosei
atason
Hi all,
Driving F30 320i, anyone encounter noise from air-con and from steering wheel when turning?:verysad:
Sent workshop still can't solve the problem. Anyone know what's wrong?
Thank you.
Re: F30 abnomal nosei
atason;1084505 said:
Hi all,
Thank you.
Hais, I've too been living with this problem for almost a month now.
Got some knocking noises when I turn my steering wheel and sometimes my tyres will feel like they are punctured with those flapping sound but when I come out and check there;s nothing.
Went back to PML but nothing wrong...
F30 316
is NORMAL ....
Hi all,
Thank you.
Noises when Steering Wheel is turned is quite a common fault, which I read from some other forums. see below
This Service Information bulletin supersedes SI 32 04 13 dated August 2013.
SUBJECT
Squeaking Noises when Steering Wheel Is Turned
MODEL
F30
Situation
There are squeaking noises from the steering spindle when the steering wheel is turned.
Cause
The steering spindle gaiter is insufficiently lubricated.
Correction
Lubricate the plastic bearing of the steering spindle gaiter from the vehicle interior and also the portion coming out from the engine compartment.
Send back to them and get it fix.
Actually the noises I encounter are not squeaking noises.
It's more like croaking sounds. Very coarse and feels like something in the engine compartment is loose etc.
barcus
