F10 520 Power enhancement
Re: F10 520 Power enhancement
Can buy new dme control unit and load in 528i software, then become 528i? How much a new dme control unit cost har?
can check what is a dme control unit.?
is the gearbox for 520 n 528 the same ?
tia
Understood from SE was 520i and 528i uses different turbo technology
SE smoke you big time...turbo is the same part number on both...
tia
My understanding is that all 5 series uses ZF 8HP45, it the same story for the new 3 series. The 7 series uses ZF 8HP70 which can take higher torque.
Mark
froggy;840356 said:
Can expert like you guys give me advice?
What to look out for and typically how much gain and $$$???
The interesting question is do we need to upgrade the inter-cooler when the ECU is power to 220+ Hp? Apparently, the BMW M Performance Power Kit beside boosting the power also upsize the inter-cooler unit. Does this give a higher horsepower & reliability?
Mark
Mark
how about the compresstion ratio?
is that the same ?
is that the same ?
Apparently there are two versions of the 20i n20 engine. One is 10.1:1 which is similar to 28i. Another is higher compression at 11.0.
Believed the engine is the same, just different way of tuning... Most likely the 528 has a much higher boost compared to 520.
Suspecting the inter-cooler in the 528 is bigger too. Hence, after-market Hp is still lower than factory tuned 528.
Cheers. Mark
Yes! Thats the first thing PML told me... But u can opt for PML's M Power Performance Kit.
Jusy wandering how much it costs?
Mark
Don't think a slight difference in intercooler size can make such a big difference.
20i engine also has m performance kit?
Thinking between a 520 and 528, which is $26k difference. If it is something that a ECU remap can do to increse the boost and mapping, then don't need to spend the additional $26k. Of course some of the moola went to power tailgate, soft close doors, rear blind.... which I don't need.
Any bros here can advice?
I drive a different car but same engine so let me comment on that;
How I convinced myself to buy a 328i over a 320i is that if a 320i can chip up to become a 328i, the 328i should be able to do even better! :sneaky:
Like that might as well buy 335i, coz 335i can do even better...
Anyway the idea is that you buy a 20i engine, change the dme unit to a new one and load in 28i software. By then your 20i become 28i for only just 2-3k nia. From there can just tune up like any 28i engine.
320 can tune to be like 328
328 can tune to be like 335
335 can ..........
Endless liao leh bros
The 28 and 20 turbo really same size ?
335 can ..........
Yes. Same part number.
ok365ok365com
