Engine vibration problem in 320i and Warranty Expiry
asianrage
Dear BMW car owners and car experts
Unlucky me to start having this problem 1 month before warranty expires. Car and engine started vibrating at rest and on driving. Took car into East Coast Centre, and they said it was due to faulty ignition coil, valvetronic actuator motor, and VANOS solenoids. They also discovered choked vent hoses and oil separators after noticing "cooked oil". They relaced all these, as well as hydraulic tappets. Took car back on 26 August after 8 days in work shop, and it happened again 5 September. So I had the car towed back to East Coast Centre today.
Before this the car drove beautifully, and I thought I would never drive another make of car again. Now I am thinking, should I try Audi, Lexus or Mercedes, if they will be more reliable:(
But as far as I know the new Audi A4 and Mercedes C class still dont drive as well as a 3 series.
Advice needed:
(1) Does this sound serious?
(2) Will it have permanent damage to engine?
(3) What if it happens again in 2 months after my warranty expires?
(4) Should I trade in my car after this repair?
(5) Anyone with this problem? How did it pan out?
It is such a waste to trade in a BMW after warranty expiry, as is common practice for any make of car in Singapore, that I am tempted to keep the car for another 2 years before trading in. But I shudder at the repair bills. The East Coast guy told me the repair bill was between 3-4K.
Dave
Re: Engine vibration problem in 320i and Warranty Expiry
Halo all
I need some advice
My CSA told me it is ignition coil again, in fact the same ignition coil that he replaced two weeks ago
He could not tell me the root cause of this repeated damage to the ignition coil
Do I take it to Juzz or BVO? Do I take it to Alexandra?
I am too worried to accept his gibberish
dude, just get them to replace the ignition coil again.
hi,
This are common problems (wear and tear) that will happen as millage increases. Good to have them changed before warranty expired as they will last for the next 2-3years.
As for ignition coil that broke down in just 2 weeks, I believed this is just 'that ignition coil'.....get it changed again and ask for extended warranty for the ignition system ONLY even after your normal 3 years period. I believe this is reasonably.
Usually this will happen when the car is about 3 years old....a couple of my friends have them CHANGED just before the warranty expired...consider luck for you too.
Please check with ur CSA regarding the warranty for the replacement parts. You may be entitled to a warranty on those parts that were replaced. However, please check with him/her 1st.
Advice needed:
Dave
Hi Asianrage, check with you, my E90 320i have slight vibration while idling at the lights, when my door is open and engine idling, the door will vibrate and you can practically see the door shaking. Is your problem like this? Bcos Im tinking of changing my spark plugs first, my mileage is approx 55000km liao and sparkplugs never changed before i tink. Thanks for your advice in advance.
u could check the sparks plugs or the engine mounting.
no worries...... :)
Hi. I encountered the same low idling problem and have sent my car in.
Believe it's the faulty ignition coil as well.
Any updates on your car?
My warranty expires in 3 mths time.
Hope it won't cost a bomb for this repair.
Advice needed:
Dave
Ya, me also has this vibrating problem... any update guys ?
Faulty ignition coil replaced under warranty.
Back to normal now.
First
First, you can tell if an online poker website is fake if you have not heard anything about it yet it is claiming that is has been wow power leveling operating for a long time. If that is the case, it should have a large number of members and everyday players. If you see a very low amount of players on the website, it is possible that the website you have been in is just a scam. Also, if wow gold the online poker website is affiliated with a large poker group, you can be sure that its operations are real and the winners really get all of aion power leveling their payments. If you see a website that is running independently, just like Action Poker, it does not automatically mean aion gold that it is a scam. Action Poker is actually being managed by Kahnawake Gaming Commission, a well known group in the industry so there is no reason for you to doubt the operations of this website. As long as you cheap aion power leveling have proof of the offline operations of a certain online poker website, you can be assured that it is indeed real.
