LL-04 recommendation is 5w-30. What is too thin?rt333;1025543 said:Will it be too thin after doing 40k km?
Is castrol gd? I saw its one of BMW recommended oil too
Sorry to bust your old skool methodology.fredlim7007;1025892 said:With turbo engine good to use a little thicker oil like 5W/40 or 10W/50.
davidtch;1025894 said:Sorry to bust your old skool methodology.
Under BMW efficient dynamic, all these viscocity FAIL.
It should be 5-30. Even ///M5 is using 5-30.
Red_Bean_Bun;1025915 said:Use the specs to gauge better. Light 5w40 and heavy 5W30 can overlap in viscosity.
IMHO - Cst should be around ~12.2 @100c (heavier end of 5w30) for current engines. I think its better thinner @40c so during startup it flows faster e.g 70-75@40c .......... personally I use something at 13.5@100c (0w40) and it did help keep the engine slightly cooler (3-4 degrees) in certain traffic situations.
That's MW.seanskye;1025997 said:Lubrication sexperts spotted.
davidtch;1026004 said:That's MW.
Rem his self lubrication post??
"also, wouldn't PML know what's the best engine oil to use?" - Can someone comment?lhong68;1026027 said:sorry guys....not famili with this. I recall in my previous E60 523i the guy at BVO used a thicker type of oil, suposedly better for the engine but i found it mkes the engine rev quite 'heavy' and feel gear change not so smooth. I then switched to a thinner type of engine oil and it was very good and ever since stick to it.
changed to f10 520 recently. I am a bit confused wiht all these comments about 0W or 5w or 30 or 40.Can someone explain?
gum xia
gum xia
davidtch;1026029 said:"also, wouldn't PML know what's the best engine oil to use?" - Can someone comment?
HowStuffWorks "What does the weight mean on a can of motor oil?"
rt333;1026062 said:Castrol Edge with Titanium better 5W-30 or Castrol Edge with Syntec better?
But if 0W-40 is better than gotta stick back to Mobil 1. I tot of try castrol this time round.
Don't limit yourself to Singapore lah.rt333;1026435 said:Anyone buy from mxtrading?
So it's just castrol edge right? I check castrol singapore website they do not have castrol edge with titanium and syntec. Any idea where these 2 products are from?
Also the website do not have 0-30 on their castrol edge list. Where can I get the 0-30?
Tks...
