Engine Inspection @50,000km
jylam
My car is coming to 50,000km. According to PML service, it'll be due for INSPECTION 1 or something like that. Any bro here send their car for inspection at 50k?
I ditched PML for a long time and i heard J4C has similar package. Does BVO have the same stuff?
Re: Engine Inspection @50,000km
60k is your typical oil, oil filter change.
All the workshops have this.
they will also check your rotor and brake pads.....normally it is due for change too...
i just did inspection I in Feb at PML cos it is still under warranty... they replaced my rear axle...
inspection I or II can be done at either Juzz or BVO... no frills...
if your ride is still under warranty, then maybe PML... else J or B is just as good... some of us here swear they are much better and at a fraction of P cost...
i know PML does measure brake pad and disc thickness with a caliper though and they record it down... full traceabilty...
choice is yours... :)
u can go to pml......tell them shld they need to replace anything, call u first. then note down the parts and change it outside urself............u will save on labour n parts ...
cos i think their checklist during inpection II is more detailed and i believe they have a certain checklist to follow for each diff inpection
Ok, Thanks for the info. I'll probably go to BVO. But the problem is I juz serviced my car, oil change, filter, etc. so I'm not sure if i can wait a little longer and ignore the service msg prompt on the computer.
