Electric Windows
anfield
New Member
Having problems with one of my electric windows. Anybody knows where to go apart from PML to get it fiixed?
Re: Electric Windows
Try giving this guy a call. He does power window repairs.
Mr. Tan 9006 9797
Does it have a "click click" sound when u wind up and down? Spoke to Bernard / BVO and he explained it is due to power window lifter unit (or whatever that is called) in the door compartment. Apparently, it's a closed box and have to change it whole.. 100+ to 200 for one, I was told. Have to fixed my front passenger side. So to your question, BVO should be able to fix, as as well other forum recommended workshops i reckon.
Apparently this is quite a common problem, had the driver window fixed a couple of months back. Most unfortunately, I started to detect rattling noises coming from this particular window recently. Not too sure whatz the problem again, hoping I was over-sensitive and it would go away somehow......
Who ask to to drive so fast on bends? YOur windows are not G-force protected. I have a solution for you.... buy me coffee at BVO. kekeke just joking.
Probably some lose panel mounting rubbing against the pulley railing... pull it out and redo it again should be ok.
cyberfreaker
