Eibach or HNR Springs?
Blacknight05
Currently on Bilstein B6 and went shopping for lowered springs.
Eibach - front lowers by 30mm, rear lowers by 15mm. But shop says will Eibach will sag after some time. No stock must wait 2 weeks.
HNR - shop says same lowered measurements as Eibach, have stock. Same price.
I am skeptical on HNR and worried it might be too hard a ride, but lowering my ride is a must.
Anyone changed your springs before and care to share your experience? Thanks in advance.
Re: Eibach or HNR Springs?
Eng Soon should have stock of those springs ..... And normally it's paired with the B8 which has a shorter suspension travel.
You would need to check if it would hit your bump stops .....
Check out Eibach with Snowdog.
I suppose Eibach should softer than H&R.
My friend is also saying Eibach has better build quality than H&R. The only attraction is H&R lowers by 1.3 inch front which is almost 5cm while Eibach only lowers 3 cm front.
My friend friend said...h&r very good.. better than eibach. The spring rate is better.
Why not go for coilovers which will give you all the control you need for height ?
Springs on its own will never be perfect in terms of height .....
KW V3 Rocks.........................
I'm lowered on H&R sport springs and have scraped my front bumper and side skirts (going over an apex) and bottomed out my front end a few times. Still learning to drive a lowered car.....But at least it's not the H&R race springs which lower the car even farther. You should check if the spring rates are compatible with your shocks. Some springs may be too stiff and lead to premature wearing of your shocks. I have no experience with Eibach springs though, but I've heard that they go well with Koni FSD shocks.
Past exp i used HNR very good! ride very comfortable.
now i am saving up for an air bag suspension setup.
having tried eibach and kwv2 and R-logic, i must say that coils are way superior in almost every aspect except price. try taxi-ing around in some members ride before you buy?
mmmhh ... I have a setup of ohlin r n t with stock eibach spring and also swift springs of 7kgf / 12kg r
camber plate from ground control ...
selling as a set.
no leaks and very good condition.
selling as I am upgrading to nitron ...
ai mai ?
This spring rate should also work for e93 ....... Calling blacknight05 ......
selling as a set.
ai mai ?
I recently changed to bilstein b6 and h&r springs due to worn stock shocks and it's really a good match with 18inch rims! Firmer than stock when cornering and ride quality is good enough with no bottoming out or crashing feeling. No loss on comfort! First two days was a bit stiff because it haven't settle in. But now after driving it for about a week it has settled in and I dare to recommend to those who don't want coil overs but want comfort and lowering to match. It's inexpensive too. Cost me about 1k for the bilstein b6 and new upper/lower rubber mountings (rubber mountings are important to change as it's also wear and tear part. they have b8 but I cannot comment as I have not tried it)from ES auto brand new.
sky88ren
