Eibach 15mm spacer for sale
Double K
One set of 15mm Eibach spacer for sale. Come with appropriate locking nuts.. Bought the spacers with nuts at $250.. Suppose to fix E60..perhaps other models can use the spacers too..
Item is very new. Fix on the car for two days. Don't like it, remove it, as I am already using wide width tyre at the rear. Interested parties please drop me a PM. Thks
Re: Eibach 15mm spacer for sale
Hi Snowmanyee
I am not too sure whether you need to do anything in order to fix the 15mm spacers. But I guess if your car is not lower too much, it should not have problem fixing the 15mm spacer.
Double K;591781 said:
Hi Snowmanyee
For 15mm spacer at the back, depending on the offset of your rear wheels, it may rub the fender inner-wall on uneven roads during driving. That is if you lowered your call's ride height through aftermarket suspension set.
You may need to do some minor adjustments to your fender inner-wall to eradicate this "rubbing", especially when you are traveling with a full load.
No modifications is needed on the spacers. it's simple plug and play.
My understanding is any spacers 5mm and below can still plug and play or 25mm and above can plug and play. Any thickness in between would need to change to long wheel lugs or cut off to 15mm extension else there is no way to fix the 15mm spacers.
I bought 12mm, 15mm and 20mm spacers from Eibach before, all plug and play.
