Firstly, the sprintbooster does not give any gains whatsoever and only makes pedal travel sensitive and shorter, meaning u step less to get more.
The 523 is VERY far away frm the 525. cams,maf, Engine Managment System and list goes on and on. Final drive if im not wrong too... compression ratio??...
a 523 with uprated sway bars will never handle like a M5 even tho the handling of the 523 is now better. It's like saying the 997 turbo handles as well as the 997 GT3, which of course does not. you've got other things there, positive/negative camber, caster settings toe in/toe out settings.
Alot of forummers here mod and go pretty hard on them, adding SC's to the engines and what not, some may be faster than a M3 but at the end of the day it's nothing near a M3, the M is still a M... same thing here.. the 523 is a 523... not a 525 or near one at least.
