E92 wheel offset ?
stevenwu
Aware that the original 18" rim model 189 has
8J X 18 ET 34 (FRONT)
8.5J X 18 ET 37 (REAR)
Anyone know for the above setup, what is the maximum ET that ones can have so that the wheel align well with the car body and also no rubbing of wheel arch...
front ET max ?
Rear ET max ? for the above setup on 18" wheel
Thanks
Re: E92 wheel offset ?
Prof, U can just go down to Hurry/Leong Seng and try out their selection of spacers till u get something that u like. I guess a 12mm or 15mm spacer will push it all the way to the fender edge. Then u can roll ur fenders too.
I am running +32 F and +27 R. But some other E92/E93 owners are running more aggressively offsets.
What tyres you getting? 275 Rear? One major consideration here, given the shallow wheel well of E92/E93.......
woow another E92 owner, let me see the car must be Black.
Anyhow, it sounds like u wanna retain stock wheels n get an aggressive look. Yeah so as Sammy the Boy says just go get spacers. You can use the eye-ball technique, ie aga-aga, and see what spacers will help.
I also dont know what is my HRE offset, probably +28 all round.
Prof is sticking with his 189 stock rims so he'll be running the 255 rear setup.
Car's white with black interior. Only MANUAL 335i coupe in Singapore! GO PROF!
Steven... congrats! And I dint know it's a manual somemore... woot! ;)
Congrats, Steven !!!
Now, Sam, go help him prepare for tiga-tiga-lima fraternity ceremony......
My mod anti-virus very strong......the Mrs :lol:
So I installed 15mm spacers at the back.....just perfect, no rubbing.
Acu, must remember that its 18x8.5J only. So width of the rim is smaller than the rest of us who are on 19x10J rear. So offset can be more aggressive.
Sam, ya you're right. I take back my words. 15MM ain't going be aggressive. 20MM maybe.
there is a different between the actual offset than adding spacer to the existing offset.
example, using his original 8.5J ET37
8.5J ET37 + 15mm spacer will have 15mm MORE inner clearance and 15mm MORE extended out to the body fender.
conclusion: using spacer will entirely push the 8.5J wheel 15MM outer to the fender.
so let's take Kenn rear offset,
10J ET27 will had 6 LESS inner clearance and 29mm MORE extended
conclusion: reducing offset but with wider width got extended more outer to the fender. almost 30MM closer to the fender. :yikess:
in the end with 15mm spacer it won't look as flush as Kenn's ride. maybe should consider 20MM.
You can use this LINK to calculate the offset before and after.
Hi all,
Thanks pal....very informative...
I keep to small wheel mainly because no $$ leow, also small wheel, less load, hopefully extra power...if there is .
If not, can not keep up with all the bros here with minimum of 580Nm...
stevenwu;327471 said:
Hi all,
Well for the stock RFT set ups n wheels, despite being 18 rather than those who changed to after mkt 19in, actually have more loads....
Congrats Steven...I see you quite often along Simei Road...honk ya if I see your white beast
Jack
Yeah, and standy for the next trashing of the Italians !!!
You just ruined your luck with going out with an Italian beauty. :lol2:
hi,
Is RFT much heaviler than normal tyres ? how much can I sell when new ? sell before car go on road...
yah heavier than normal
not sure bout re sale price. those who traded in theirs cud perhaps shed some lights
