E92 Tyre Size
spidey3
Hi bros
Thinking of trading in my stock rims and tyes for Breyton Race GT-P with CSC-5 235/35/19 F and 265/40/19 R. Just wondering if this is the right tyre sizes? Should the rear be 263/35/19 or any other better size instead? It's a 335i.
Thanks for advice!
Re: E92 Tyre Size
Wrong.
For 19"s......
235 or 245 F, aspect 35
265 or 275 R, aspect 30
Re: E92 Tyre Size
spidey3;626983 said:
Hi bros
Thanks for advice!
Hi Bro,
I keen in your stock rims. BTW is it 18" and staggered.
But I dont want the run flat tyres.
Pls advise if it is ok with u.
Cheers.
Re: E92 Tyre Size
kenntona;626984 said:
Wrong.
For 19"s......
Oops typo error i'd meant 265/30/19 R. Yes u're rite Kentonna thanks!
Re: E92 Tyre Size
WHITENIGHT;627006 said:
Hi Bro,
Cheers.
Hi bro sorry I went ahead n traded in my rims liao earlier tis pm. Thanks for interest..
Re: E92 Tyre Size
Hi all,
Plan to change rims so asking:
beside the tyres size for 19" as suggested.
how are rims offset ? front and rear ?
front for 9.5J, offset = ? (for 235)
front for 9J, offset = ? (for 235)
rear for 10J, offset = ? (for 265)
rear for 10.5J offset = ? (for 275)
which has the perfect flash looking ?
tyres narrower than the rim look strange :(
Re: E92 Tyre Size
E92
8.5J x 19 = 235, possible 245
9.5J x 19 = 265, possible 275
Offset for the front should be ET30, rear is ET28-ET35.
275 will need Neg camber and fender rolling if run ET25 and below, tyres like Toyo T1R (narrow shoulder) type.
Re: E92 Tyre Size
my 275 on 9.5J still needed fender rolling as lowered.
tom_ting;630948 said:
E92
Re: E92 Tyre Size
E92
Hi all,
To make sure tyres is wider than the rim look, front 8.5J will go with 235 ok ?
Rear 9.5J will go with 265 ok ? I am planning to use Asym F1 tyres, 19"
What is the max offset that I can go before I need to roll my fender
front = ET30 ?
Rear= ET28 ?
assuming I used the above setup 8.5J / 235 ; 9.5J / 265
Or what is the BEST setup to recommend please for 19" e92 coupe usage.
Thanks in advance
