E92 e-throttle
cheangv
Do you find the initial throttle response jerky. Maybe it takes getting used to but I find that if I jsut tap on the throttle when moving off, nothing happens and when I try to tap a bit more, it suddenly gives me a jolt in acceleration.
Does Vishnu smoothen out the throttle response?
Re: E92 e-throttle
You talking about D or SD mode? SD mode can be jerky if you are heavy-footed.
V2.02 will smoothen out the delivery. V1.47 feels raw.
Re: E92 e-throttle
D mode start from gear 2.....so must apply more pressure...switch to DS mode...response is instant but more jerky/raw feel
Re: E92 e-throttle
Referring to D mode. Ahh, didn't realise it starts from 2nd gear which probably explains why it behaves this way.
Re: E92 e-throttle
is it? Even for the E90 320i? Starts from 2nd gear??? WOw I didnt know that, then what is the first gear for then??? hmmm.....
