E92 335ia coupe idling problem
cjohntoh
Can anyone help me on this problem?
My ride is a E92 335ia DCT coupe . Everytime when I come to a stop, my rmp will rise to 1000 than back to 750.
Car feels sluggish when moving off from stand still. When to workshop, check on the sensor, nothings wrong. Clean the throttle body, but still the same. Can anyone help me? Thanks...
Re: E92 335ia coupe idling problem
Any fault codes?
Sounds like your intake manifold requires some housekeeping.
Number 2 ignition coil faulty?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
cjohntoh;1109857 said:
Hi, my 325 E92 recently also have the same issue. My mechanic told me most probably is carbon build up that lead to idling hunting and told me to whack my car to clear the Carbon which I did by driving to KL. Surprisingly he is right and hunting problem solved that you can try in NS highway.
hi johnson83, I did when to NS highway, but problem remains...
MAF issue, DCT issue ... DME issue ...
cjohntoh;1110089 said:
Sound very serious.. Oh No.....
Not serious ... just need some readjustment.
Update your DME modules.
cjohntoh;1110684 said:
What's DME modules?
Free kopi ....
Haha
ECU - then also update your TCU
if still got then that means MAF/MAS issue ...
Last but not least spark plugs / coils ..
Ecu is a general term for a bunch of controllers that your car have. Each controller manages a specific set of functions a lights, audio, engine, gearbox, roof, antenna, instrument cluster.
The Dme manages your engine.
Other marques might call the gearbox controller - TCU.
BMW calls it the EGS.
N55 and N54 engine - No MAF sensors.
BMW of pml
Still call it tcu in their work order chit.
Maf / mas how do you word it then ?
Red_Bean_Bun;1110729 said:
Turbo engine is map lah .......
Boss,
MAP stands for ?
Pai she noob how to word all such stuffs.
MAP is manifold absolute pressure ..............measures air density for AFR.
SUPAN;1110734 said:
Boss,
MAP stands for ?
Boss,
May I ask what is the sensor attached to the air box then ?
MAP ?
