E90 wheels on E92
khkh74
Hi folks...one newbie qn. i have just upgraded from my current E90 to E92. But i was wondering is it possible to transfer the aftermarket wheels from my E90 to my new ride? will it fit ok? need any spacer?
thanks in advance
Re: E90 wheels on E92
thanks in advance
Should be able to fit.....but what rims are those on your previous ride E90? Original or Replicas?
its some 18 inch replicas....changed it 6mths ago...abit wasteful if i just let it follow my e90
Oh i see,
most of the replicas sure have to put spacer...........
maybe can do a trade in to a tyre shop if you see something better in future....
yeah...tts what i thought so too....
thanks alot for your info...appreciate it :)
does ur e92 comes with 18inches rim?
if yes, u should just keep it.
The answer is not so straight forward - is your E90 the PFL or face-lifted version?
If PFL, yes, your wheels can fit the E92.
If face-lifted, no. New E90 has different offset.
PFL - pre face-lift
Ah Hia
Simi Difference???
My cousin new E90 put in the 335 Stock 18s.....any issues?
Stock figures :
E90 18x8 F 18x8.5 R - offsets +34 / +39
E90N 18x8 F 18x8.5 R - offsets +34 / +37
OIC
So need wider rear wheels to make 'em flush ya?
Yeah...... a E90N fitting a E92 wheels........
hi Kenntona, one of your tread mentioned that if we uses after market wheels on E92, we need to change to a longer lug, does tt apply for my case as well?
Depends on thickness of mounting pad.
