E90 smoke coming out of bonnet.....
Re: E90 smoke coming out of bonnet.....
Will try to take 2moro.... not sure if its from the exhaust.... simi is VCG?? :eek:
VCG is valve cover gasket ......
If gasket is blown .... Sometimes smoke will also come out from exhaust.
Bro casper, be prepared .our beloved bimmer will give us surprises at times.be prepared to spend money on repairs and frequent visits to ws.R2D is good.go see Rod.he should be able to help u
true dat.... hahaha... but wat to do... Ai hiong siew tio ai jiam siew lor...... prep for the worst when i bght the ride... but didnt realised every week also got kang tao.... =p
Dun worry bro.after you clock enough weekly visits to ws.it will become monthly visits.i also kanna kangtao every month.used to it liao.
Hope my 3 series don't give me weekly visits to WS.
True. I still remember when I first bought the other car I went to that b******* dealer's ws to bang table almost everyday.
With a good ws, I only go once every few months, and mostly for mods......... Vroom vroom!
To add to RBBro's advice, if the ws diagnoses the problem as the VCG and agrees to help you re-do it for FOC, make sure the ws checks the VCG rubber for micro-tears. If it was new when they first installed it and leaking after only a few months, sounds like they screwed up the original job and cut the rubber. The VCG is like a condom for the engine, you wouldn't want to put back one that already has holes in it.
If the problem is the VCG and they refuse to do it FOC and charge you for it, my advice is to go elsewhere. These guys probably CMI and will likely screw it up again.
Whichever ws you choose eventually, get them to check the vacuum pump seal as well. It's a common task job and might as well replace it with the valve cover out of the way. Of course, a good BMW ws would not need to be prompted to check that.
The purpose of this forum is for us to share so that others don't have to suffer the hard and expensive way. Our rides are fantastic but the people who maintain them make a hell of a difference. Those who curse and swear (incl me last time!) at their rides probably never got a good ws, esp when they first got the ride. Anyway, good luck!
seanskye;1056954 said:
Agree to that. I lost count of how many things I've fixed up on the sedan. But the good thing was after spending so much, the FC improved from 8.5km/l to 10.5km/l....... (Not that I care about FC!)
Your FC is pretty good, I fixed all the problem but my fc still remain the same.. =(
Gotta find a good and competent workshop first (like sponsors WS), get some of the preventative maintenance done (i.e. change those wear and tear parts before they fail) can avoid some of these unexpected repairs. BMW really a lot of parts you can and need to change.
If you fixed them all up good, then left two things to try to get better FC:
1) change engine oil to German Castrol 5w-30 (sure made a difference in mine)
2) desludge your engine, if your engine is already sludge up, it will not be efficient whatever else you do
Mine was 8.5km / l previously, after done #2, it went up to 9.5km/l, now with GC it's closer to 10km/l.
60% city, 40% highway.
seanskye;1056943 said:
Send in to R2D. Woodlands, near your place. Rod takes great care of our cars...
Was at R2D... but it was closed.. mus make appt one?
They open in the afternoon.
perating hours
Monday – Friday 1:00 pm – 11:00 pm
Saturday 10:00 am – 7:00 pm
Sundays & Public Holidays CLOSED
By appointment only
oil leak ... every e90 will have it ... sooner or later
when the oil drip onto the exhaust/extractor ... smoke come out of the bonnet
i kena that too
Looking at where the oil is ...... Better check the oil filter housing gasket as well as the VCG. Quite a bad leak ......can see small pools of oils at both locations.
After looking at the pics, I think your vacuum pump seal is gone. And likely either the VCG rubber gasket or more likely the flange (you can see it is wet).
Call Rod up quick. I've pm'ed you.
I m at R2D nw... will update d story lata
nhacaivinbett
