Re: E90 - Oil Change
Genie47 of MCF and Ken4 of Toyota forums are the real gurus.... I only find out enough to use the right oil They send their used oil to Dyson in USA for oil analysis.... whereas I just look at other people's used oil analysis
If I were you, I will not mind using either the SLX-A3 or the Mobil 1 0w40 on Singapore roads. But the day before track... since I KS, I will put in Castrol RS 10w50. And on the morning of the track day.... drive slowly for the first 20 minutes (i.e. in Singapore) till I hit the NS then I will WOT :laughlik: At least I won't worry about protection if I decide to blast it hard on the track. Check oil level before heading back to SG, top up if necessary. Once back in SG and till the next servicing, just don't WOT in the first 20 minutes.
Somehow, Castrol RS 10w50 does not have the BMW approved oil thingy... but it has been getting very good numbers in the used oil analysis, so should be fine.
louis said:achtung,
i think you're bmw-sg's very own Genie47...... muahaha,
may i ask, do you think 0w-40 mobil 1 or Castrol SLX-A3 would be more suitable for a car that sees light track use and is revved to high rpms frequently? or perhaps other oil recommendations?
