wt_know;629693 said:323i & 325i both share the same engine N52 and 2.5L
323i is detuned means the ECU is tuned down to produce lesser power and there is a "slight" difference in hardware especially the intake DISA
some says you can't just flash the 323i ECU and walaa ... it becomes a 325i
if you are getting a used unit, it's a no brainer to get a 325i as the price should be the same or difference is negligible. get a 325i which is the real deal
Peterpan;629692 said:Hi bro,
323i and 325i both are 2.5L but giving different output power/ torque. Are both models sharing the same engine? Are the difference in performance due to tunning?
Anyone can throw some lights on this?
Thank you.
Peterpan;629702 said:Thanks.
So it might mean that 323i cannot be re-tunned to release more power like 325?
wt_know;629728 said:if this can be done by simply re-tuned, there will be no 325 on the road la![]()
